budbustacap
how long do these lipo 2s and 3s batteries discharge/run for? On my Senton 4x4 3s with the 100blx esc whatnot.. pretty much stock..
Depends on the lipo brand/quality and Ah rating. Also the terrain you’re running in makes a huge difference as well as driving style.how long do these lipo 2s and 3s batteries discharge/run for? On my Senton 4x4 3s with the 100blx esc whatnot.. pretty much stock..
Ok. So 20 mins at least on the dirt is pretty good I think.. i goes so fast and really loses traction if I gun it flat out.Depends on the lipo brand/quality and Ah rating. Also the terrain you’re running in makes a huge difference as well as driving style.
For instance, on a decent quality 5000mah pack on the street with moderate driving you should see about 20-30mins of runtime. Put that same setup on grass and it will cut it in half, 10-15mins. Drive it like you stole it in the street and you get the same 10-15 mins.
Use a junk lipo and you may only get 10 on the street. ??
11.1v 5200mah 50cDepends on the mah and how hard you run them, and what you run them on.
AndOk. So 20 mins at least on the dirt is pretty good I think.. i goes so fast and really loses traction if I gun it flat out.
11.1v 5200mah 50c
Run on hard dirt
