Thank you very much, I really appreciate the fact you answered me, you helped me a lot.It probably comes at a low charge for safety reasons, so definitely charge it up before you run.
Lipos don't have memory effect like older battery types so it can be topped up any time. No need to discharge.
Make sure you keep it at storage voltage when not running, for longest lifetime. And in a safe (fireproof) place, just in case. Charge it before running and storage charge when you're done.
Is the voltz vault a good Lipo sack?Pick up a good liposack that can handle the capacity of battery you intend to use as well.
@nino mentioned good advice. Storage wise- I set my batteries for storage @3.8-3.83v per cell.
Do not charge over 4.2 volts per cell, and do not drop below 3.2v max per cell. People have varying opinions on the cutoff voltage, I personally call it quits at 3.7v per cell for most packs, and 3.6v per cell on newer ones. This is just where I chose to cut it off at- others may or may not go much lower than myself. See what the manufacturer of your batteries state.
Thanks a lot for the information buddyPick up a good liposack that can handle the capacity of battery you intend to use as well.
