So, I recently had a cell dip below 3V (I think my balance lead was off by 1 pin in the voltage alarm, and when one cell gets low, it drops fast).This.
Stop looking at the capacity meter, the voltage tells you everything.
Above 4.2V = house on fire
3.8V = always at this level unless you are charging and running your truck shortly thereafter
Below = 3.5V degrading quickly
Below 3V = dead lipo, discharge to zero, dispose and buy a new one
You, sir , have better than average knowledge of this topic. I do thank you and jkflow (plus others) for sharing your know how.So, I recently had a cell dip below 3V (I think my balance lead was off by 1 pin in the voltage alarm, and when one cell gets low, it drops fast).
My charger is able to recover cells in this state (although, I assume there's a lower limit beyond which it won't) by charging very slowly (0.15A) until the cell voltage is above 3.5V.
I understand that I've likely done some permanent damage to the battery, but I still plan to use it. In fact, the cell this happened to is only reported as 4mΩ.
Here's an interesting link about this: https://www.instructables.com/Restoring-over-discharged-LiPo-Lithium-Polymer-bat/
And don't charge them unattended!You, sir , have better than average knowledge of this topic. I do thank you and jkflow (plus others) for sharing your know how.
That being said, The last thing anyone needs is a battery to go WAY SOUTH on us, (catch on fire, etc)...... so..... myself, being relative noob to much of this, I will stick to the 3V and below = dead, discharge and discard, just for the safety factor.
I am in NO WAY challenging your know how or methods..... I am sure you are on top of all this, but a message for those out there who are not REALLY ON THE KNOW like these guys are, PLEASE FOLLOW THE ABOVE GUIDELINES!!!! BE SAFE...... go on YouTube and watch a video on LiPo fires...... it made me go and get metal ammo boxes and follow the above..... (just echoing your first comment above)
THANX you guys for sharing this info......other than being hit in the head by a Kraton 8S at top speed, battery care can be the most dangerous aspect of this hobby.....
