- Typhon 6s
Anything from 3.75-3.85v is perfectly fine for storage.Okay @Mongoose. That’s what I needed to hear. I’m going to try to do the “Storage” mode on this one particular battery one more time.
4.25! Really if you’re any over 4.21 you’re doing serious damage (exception is lithium high voltage batteries)Check your IR's. Sometimes chargers have anomalies. Verify numbers with another device, lipo checker, VOM or similar. But the HTRC display seems normal. 4.2v -4.25 per cell is is FULL charged. Your cells are at storage volts.(3.8v) Seems like your cells are not quite balanced yet. Use the balance mode at storage voltage to level them out. I find that IR's per cell drop at as they approach 4.2v. So I am only concerned with IR's when full charged. That's when it counts the most. IMO.
LMAO my badHe is the OP lol
I can’t live with this in my home.
I know I am! I wish it hadn’t seen those Lipo battery videos on YouTube. Seeing them just spontaneously blow up, no pun intended, kind of blew me away. I’m not as scared as you might think. I just bought a 2nd car last week.Man you are super paranoid!
I think I found a solution for transporting my Lipos to the circuit. I found an old one here in Japan that I can pickup for about 7000 USD.hmmm. I think I understand now.
I want whats in that.I think I found a solution for transporting my Lipos to the circuit. I found an old one here in Japan that I can pickup for about 7000 USD. View attachment 61328
#Fakenews
The above you mentioned are Lithium Ion packs in consumer products with low Mah ratings and Lions are not volatile in a fully charged state unlike Lipo's which are volatile at 4.2v per cell(charged). Lions are designed to be charged and stored fully charged. Lipos are not designed to be stored fully charged for lengths of time. And, the larger the Mah, the larger the bang when they light up. These lipos are hobby grade mass produced with minimal standards at manufacture, hence the many fires we see on YT as of late. If you respect them they respect you for the most part. But I've even had new lipos that were questionable and smelled sweet. Those are flawed unsealed packs from manufacturing. A decent company will replace them, because they know there is an inherent production failure rate with Lipos. And most are not hardcased so they damage easily when bashing. When a fully charged soft case is breached from impact or damage, air mixes with the polymer and it reacts fast. Hard to put out. You just let them flame out. So you want them contained until the reaction stops. Using a vented container/ fire proof bag helps.I guess it's possible you do, but I don't think you store your power tools in a special bag, or your laptop in a special bag, or your phone in a special bag. Why would you store these in a special bag?
“They just expand till the sheets rupture and ignite with oxygen”.Lithium Ion is different than Lithium Polymer. UL listed Consumer goods use Lion packs with safety circuitry. Most RC packs don't have that feature. They rely on a balance lead to monitor the cells at the charger. I agree that this hobby can draw a lot of needless kneejerk products that are not needed. Hence, lipo bags that appear non functional. Some are even BS and not worth anything. The better ones are cheap insurance however. Lipos generally don't ignite when stored. It is at the charging process where they usually ignite or when they are in use charged and under load and/or damaged while bashing. Stored at 3.8v/cell they are fine. Lipos can be shaped to size for specific applications.
I have many power tools. But they are all Lion powered. (18650's in series) 18650's have safety circuitry. They can safely vent also. Lipo's cant vent. They just expand till the sheets rupture and ignite with oxygen.
Baby steps. We all started somewhere. I use Deans Ultra Plugs (T-plugs)on my Crawlers and low voltage rigs. My 6S rigs I am using XT90's.“They just expand till the sheets rupture and ignite with oxygen”.
You have me scared “S%&#$less” right now. I don’t ever want to see a Lipo bulging, getting ready to Hulk out on me, hitting me with gamma radiation then suffocating me. I almost dropped one the other day. Clumsy me. I ran to get my fire blanket and mitts.
Everything is a learning experience though. That’s the good point. What have a learned so far? Not much, but here’s what I got.
I love this battery right now. View attachment 61337
I love the numbers I see on the charger. Nothing funny about it. Stayed real cool while bashing.
I’m also a big fan of “Deans” T adaptors. No chance to make a mistake there. That’s how things ought to be. I use the Deans to charge. I found a nice adaptor that goes from EC5 to Deans. Life’s simple.
I also like EC5 adaptors on my batteries. With my Typhon and IC5 everything just clicks nicely.
I’ll learn more about the other connectors in time. Right now, I just need to learn the basics. I still haven’t figured out differential oils and shock oils. That’s my next big challenge.
I use the T-plugs only for charging. Keeps me in check. Red to red, black to black, just like that.Baby steps. We all started somewhere. I use Deans Ultra Plugs (T-plugs)on my Crawlers and low voltage rigs. My 6S rigs I am using XT90's.
T- plugs will melt with high amp use as I learned. And when bashing hard they do come apart and disconnect from impacts
