What brand of batteries are they. gensacearespammers bashing by any chance?Anyone have issues with lipo's getting hot? I run 4s in my Outcast turned into a Kraton. 2 5200 50c batteries. They get around 140-145 at the end of a bash. I run a 16t pinion, motor is around 140, and esc is around 130.
My 45c 5200 hobbystars also get a bit warm. Definitely a bit underrated compared to other 40-50c packs I’ve owned. So far no puffing and no out of wonk cells 80 runs later at least.Well, the 50C could be a bit exaggerated on the zee's and with more capacity on the 6000mah, they are able to put out more current than the 5000's just due to the cell's size. I have a 5200mah hobbystar that's 45C and it gets pretty warm running in my 3S trucks.
I had 2 of them at first. Was intending on running them in my smaller 1/10 trucks as the stampede battery tray is limited to the smaller hard case pack dimensions. One of them dropped a cell after the 4th use. Instead of buying more, I tore apart some of my old 2S SMC 7200mah lipos and built a couple 3S packs out of them. Since they are so much taller, I don't even use the other 5200 that was ok anymore as the battery hold down had to be modified to use the 7200's in my stampede. I could still run it easily in my ejato though as it just uses velcro straps.My 45c 5200 hobbystars also get a bit warm. Definitely a bit underrated compared to other 40-50c packs I’ve owned. So far no puffing and no out of wonk cells 80 runs later at least.
Eh from what I hear you’re not the only one to have a dud hobbystar. I mean you pay less for them compared to other brands they don’t match the cells quite as well, so it’s just a matter of getting luckyI had 2 of them at first. Was intending on running them in my smaller 1/10 trucks as the stampede battery tray is limited to the smaller hard case pack dimensions. One of them dropped a cell after the 4th use. Instead of buying more, I tore apart some of my old 2S SMC 7200mah lipos and built a couple 3S packs out of them. Since they are so much taller, I don't even use the other 5200 that was ok anymore as the battery hold down had to be modified to use the 7200's in my stampede. I could still run it easily in my ejato though as it just uses velcro straps.
So far, the 6800 3S hobbystar packs are holding up well. They are too big for the stampede, but I got them to use in my outcast and savage flux. Guess the bad 5200 was just a dud.
Or unlucky.Eh from what I hear you’re not the only one to have a dud hobbystar. I mean you pay less for them compared to other brands they don’t match the cells quite as well, so it’s just a matter of getting lucky
I've had very good luck with mine. Better than SPC, SMC, and my budget Turnigy packs. The fact RCJuice is 5 minutes from my house ? is a big plus too?.Or unlucky.
After seeing the hurting @Rich Duperbash puts on his 6S packs, I figured I'd give them another try, which is why I ordered my first set of the 6200's. I got the second set due to a $10 off sale. Nice pack for $40 a piece. Not bad even at $50.
Now that's just not fair! All those awesome places to bash and the parts support to boot!The fact RCJuice is 5 minutes from my house ? is a big plus too?.
Thanks very much Brother ?. I do my best to keep them dialed and up to task?. Wrenching and tuning is atleast 1/2 the fun.I thoroughly enjoy your videos @Rich Duperbash. Hard to believe your rigs hold together sometimes.
I only run 6s single hard case packs. ?Do you prefer 1x6S or 2x3S?
I have only run the True Spec Premium 6S 4500mAh 85Amps/90C but it's puffing more each day after less than 20 runs on a stock Outcast.
