My apologies, I'm sure this question has been addressed a hundred times but I did try the search function and could not find what I was looking for.
Apparently it is normal that when you start off hard the front lifts just high enough to allow a lot of the power to go to the front wheels, ballooning them up and a reduction of real 4 wheel drive traction, not to mention the accelerated wear to the middle part of the tire tread - tires being about $50 for just one pair you'd want to avoid premature wear. Here are some things I've read about locking down the center differential:
- Mash silly putty or silicone earplugs in there;
Q: which is "safer" to avoid damage to the differential itself?
Q: which is more reversible if I decide to go back to stock oil later on?
Q: What common (automotive, marine, etc...) thick-ass grease could I put in there to stiffen but not lock the differential?
- Creating unacceptable stress / damage to the front and rear drivetrain;
Q: True or not?
- Makes steering control harder / worse;
Q: True or not?
Q: What are the trade-offs of doing this, is it "worth" it? (subjective, I know).
Thanks!
Q: True or not?
Q: True or not?
Thanks!
