Tony R
- Talion
Not sure if there's another thread for this but i'm having a difficult time with the front drive-train/steering on my talion. I realize it may be my fault partly, but whats goin on is if the pillow balls are screwed in all the way even with the stock spacers on the arms soon as you turn left or right one or the other driveshafts lock up when you hit the throttle depending on which way you steer. I know loosening the pillow balls helps but it eventually ends up being the same and if you keep it loose you end up having to loosen it even more to free it up and if you just choose to run it like this eventually, the driveshafts will just yank out of the diff cups cause of the stress or how close they are from popping out and will just wear them and the arms down. That said i've replaced everything that was causing this and it was actually good like it was when i first bought the car. Diff was moving smooth even when steering all the way left or right suspension flexed or not. Took it to a local track(now i'm not a very bad driver lol i make mistakes sometimes but i'm not bad and i tuned my suspension a little bit to make it a bit more plush i guess) but this track isn't very heavy on your car if you stay away from the walls etc and i ran it for the day and it was fine for the meantime. So I took it home and now im having the same problems, they're locking up again. I really don't know what i'm asking, just trying to see if anyone has been having the same problem.
