Hey guys, as the title says, I'm wondering about 2mm hex driver with longer shafts. I've got the MIP speed tip set that I use with my Kobalt double drive screwdriver for most everything. But the one thing they don't work well for is going down the axle(?) thing to take the diff apart on my Granite BLX 3s. I love the MIP brand. I've rounded other decent quality bits already, but not them! Will the yellow handled MIP driver work or does it have the same length and problem? If that one is too short also, is there another high quality 2mm driver with long enough shaft you can recommend?
