The standard 168mm dogbone & or shaft cups are too short to use with my lock spool. I have an extra 10mm space so the dogbone keeps falling out.Not sure what you are asking?
There are 6 driveshafts in all....
What is it that you want to do?
Wow, that's a dilemma, I got ya now..
Hmm......
Short at the rear DB shaft?
I imagine you are swapping the spool.
Are we taking about all stock parts, spool and dog bones. Arrma has not changed out the specs whether spool or diff. I have both an Infr.( diff) and a Lim(spool) Front Dog bone fits fine, just not the rear? Maybe not assembled right The spool uses spacers. If aftermarket spool, maybe the issue. How old is your Lim.? Looks like we are talking about your Lim?
Edit:
You might have the spool installed Backwards, Try reorienting it. Do you have pictures of the chassis to post??? There are 2 red spool shims . One smaller than the other. The wider one faces the rear. That may be the 10mm you are trying to gain???
Need pictures and more info. Is all stock parts?
Are you using the stock motor position (Left side), or did you move it to the right hand side.
Motor's on the right. Nothing is stock besides fr/rear diff bc my new spool set-up is too short. I'm sure everything's in it properly. Spool is too short. @ least 10mm.Wow, that's a dilemma, I got ya now..
Hmm......
Edit:
Unfortunately not. Bore don't match. Cups are already on the edgeThe only longer one I've seen is 170mm: https://www.ebay.com/itm/45-steel-r...ft-avoid-vibration-for-1-7-Arrma/203004505663
Can you get the factory spool shaft and install the rest of the new spool components on there? Or maybe add some spacers so that the drive cups are further out to buy you a few more mm?
I have that same 170mm shaft also. It fits in the stock setup with less pin slack in the drive cups snug to avoid vibration.The only longer one I've seen is 170mm: https://www.ebay.com/itm/45-steel-r...ft-avoid-vibration-for-1-7-Arrma/203004505663
Currently running stock spool. Looks like I'm gonna have buy a whole new setup on the smaller bore shaft.I have that same 170mm shaft also. It fits in the stock setup with less pin slack in the drive cups snug to avoid vibration.
However, it seems the OP has way more than 2mm slack and DB falls out. He said 10-15mm of too much slack.
I agree, try fitting the stock spool back in. Or measure out the stock spool against the Upgrade spool.
My question is if the rear DB is too short now, is the front DB too long????
Got me? IDK. ?
Picture is above^^^At this point, maybe some pictures would help.
