Goofy21792
- Infraction
I'm looking to put 3 gcrc fans on my motor and 1 on my ecs I don't get on Facebook anyone know of a link where 8 can buy these it for a 8s infraction
Nice work.You should try do DIY it, save a ton of money. This is what I came up with when I didn't want to cough up a ton of $$$ on fans.
Llolol. 34 week lead time. No thanksIf you go DIY, I recommend these: https://www.mouser.com/ProductDetail/108-THA0412BN
Not the highest output but the aluminum housing holds up WAY better than plastic for bashing. You will also need some shrink wrap and a connector. Really I don't think the price of Game Changer fans are insane after you consider the little extras and labor. If you're handy you can definitely save some money. Also a good skill to build in this hobby.
Nice work.
D..I..Y.. more personal satisfaction.
I had contra-rotating fans at one point. Each fan had 2 in them, spinning opposite directions.
I thought it was funny since those lead times are real-life in my world. Insulation is insanity right now.Stock:
522 Can Ship Immediately
I guess if you need more than 522 of them you'll have to wait 32 weeks...
How do you suggest mounting them with an offset from the motor to avoid backflow? P are suggesting not to bash with these but that's when I need them. Running 1650kv and haven't really geared it very high but it gets hot where I live. Lower kv? Preferably do t want to run a fan at all?Keep in mind that you can pick any 12V DC fan with comparable cfm, the way they are mounted above is wasting about 30-40% of actual air flow due to back pressure. You can easily pick any fan 20 CFM or higher and you have a great solution that surpasses any gamechanger setup. They are in the 25CFM range if I recall correctly.
newark, digikey or mouser all have stock. If in doubt feel free to ask, yes you will have to do some soldering or buy yourself some adapters. Spending $50 per fan ....well it's your money.
Digikey stock today for alu framed, filtered out the other 20+ plastic versions.
