Go ham, 50tooth spur and 34tooth pinion. See what happens if the motor burns oh well just get another one for 40.00 bucks. You will need a new spool found on ebay or the 50 tooth spur set up is on Amazon for 27bucks. How low do you have your suspension from the ground front and back? Curious.I was able to hit 69 miles an hour with the 26 tooth pinion gear that is included. Has anyone had any better luck getting more speed with a larger pinion gear? If so, wondering what gear you would recommend without overloading the motor?
I think you should stick right at that speed purely so you can tell people it goes 69 miles per hour, then paint a body with a big ol' pink 69 on top.I was able to hit 69 miles an hour with the 26 tooth pinion gear that is included. Has anyone had any better luck getting more speed with a larger pinion gear? If so, wondering what gear you would recommend without overloading the motor?
