tremblayrene603
Looking to find the best but not break the bank tool kit and stand for my vortex so many options so many different prices any help would be awesome thanks
MIP tools are the best by far but brands like Dynamite make drivers with replaceable tips. Whatever brand you choose, know that any screws that go into metal on an rc, likely have thread lock on them. Heat them up first so that you don't strip screws and ruin tools. As for stands, There's inexpensive ones you can buy that swivel like these, which are good to have.Looking to find the best but not break the bank tool kit and stand for my vortex so many options so many different prices any help would be awesome thanks
So jealous of your skills at posting links! Someday I'm going to learn.These Neewer hex drivers have been solid for near 18 months. I have MIPs for certain things but they are a bit delicate due to the hardened nature of the steel. I’ve snapped two and broke one by dropping it. I use my Neewer set for most wrenching and they have been a surprisingly good for a $15 set of drivers.
This 7mm driver is good for wheel nuts and the 17mm is great as it’s long and fits deep wheels nicely.
For tire glue the bob smith industry rubberized ca glue is really good. For lubrication needs I really like superlube grease and oil.
I really like this affordable ($50) soldering iron. It is built extremely well, hits 750-800f very quick and holds it well. I’ve used it a lot since I got it nearly a year ago. Make sure to get lead solder, not the lead free kind. Good shrink wrap is helpful also. I like the marine 3-1 adhesive kind.
This combo bearing tool and mini t-wrench is very handy.
That’s all I can think of now…
Neewer - Set of 4 Hexagonal Screwdrivers Made of Titanium Nitride with Coloured Handles.Compatible with 1.5, 2, 2.5 and 3mm Screws. https://a.co/d/hDazQaI
Antrader Hex Screw Driver, 7mm High-carbon Steel Socket Wrench Screwdriver Carburetor Adjustment Tool https://a.co/d/6Zbd2Cn
Hobbypark 17mm Hex Adapter Wrench Tools w/4mm 5mm 5.5mm 7mm Cross Sleeve for 1/8 1/10 1/12 Scale RC Cars Trucks Wheel Hubs Nuts (Black-Red) https://a.co/d/fCH7xmc
vanpro RC Ball Bearing Driver Install Remove Repair Tool,Cross Wrenches Maintenance Tool Small Sleeve Hex Socket Wheel Spanner for RC Model Car Truck Buggy (Color: Black) https://a.co/d/0n9kK3E
Bob Smith Industries BSI-118 IC-2000 Rubber Toughened CA Glue, 1 oz, Black https://a.co/d/h7wKdyW
Super Lube 41160 Synthetic Grease (NLGI 2), 14.1 oz Canister, Translucent White https://a.co/d/336uop1
Super Lube 51010 Oil Super Lube,Translucent white https://a.co/d/1vSpVcn
Tilswall Soldering Station, 65W Solder Station Welding Iron with Smart Temperature Control (392°F-896°F), Extra 5pcs Soldering Tips, Built-in Transformer, Ideal for School Lab, Hobby, Electronics https://a.co/d/38sBD4V
I copy and paste. That’s all lol. Only took me a year and a half to figure out howSo jealous of your skills at posting links! Someday I'm going to learn.
As far as stands I actually use one just like the stand that @Notorious J posted. It even came with a hex tool kit. The quality of the bits are pretty decent, but I have about 3 different sets of hex bits. I really do like the stand though, makes wrenching alot easier.MIP tools are the best by far but brands like Dynamite make drivers with replaceable tips. Whatever brand you choose, know that any screws that go into metal on an rc, likely have thread lock on them. Heat them up first so that you don't strip screws and ruin tools. As for stands, There's inexpensive ones you can buy that swivel like these, which are good to have.
View attachment 276884View attachment 276885
It’s what I do. Work well and also serve as storage stands.I know it’s lame but I use a yoga brick foam as a stand to work on the car.
It’s cheap and does the job + I can use it for other things!
Each of my cars has a yoga brick for storageyoga brick foam
Me too! And the foam is also pretty stiff but easy to cut and shape so can be used as a raw material for making some other things. Like I cut a big chunk to provide center body crash support (for when you land on the roof) when I swapped out my fireteam body. Just double taped it to that plastic saddle that's around the red cross brace. Not pretty of course, but very effective and super light.I know it’s lame but I use a yoga brick foam as a stand to work on the car.
