Barwolf9828
So far I bought everything that hot racing offered but still haven't found anyone that sell aluminum a-arms for the kraton v2. Can anyone point me in the right direction
Trying to make it bullet proofAluminum A arms are not a good idea. No flex.
Hey man. I agree, the arms do need to flex. Have a look at the RPM arms. They have more water in there plastics which makes them more flexible and less prone to breakages. Hope that helps.Ty you all for the info
Am just looking for tougher parts.
Being a trucker I don't get to play with the kraton v2 very often and when I do it seems like something brakes 1st time I did I broke the front diff and had to replace it the I broke a shock. Now it sitting under the bunk waiting to get home so I could fix the shock
How do I get to the RPM website?Hey man. I agree, the arms do need to flex. Have a look at the RPM arms. They have more water in there plastics which makes them more flexible and less prone to breakages. Hope that helps.
I have ordered what he Gka has for right now and also order everything from hot racing. Am just waiting to order tougher tires. I already blow a Factory tire. Re thinking a need to redo the tires bc the one that blow was Factoryto toughen up the kraton I suggest either the GKA or Hot Racing Chassis braces, the GKA or Voltage hobbies servo mount, an aluminum center differential mount, and Shim the differentials. Then it's always nice to have extra parts around. Ebay is your friend in this as there are a couple guys who buy new Cars and sell the parts. Cheaper than buying them new for sure. I now have a set of Front and rear arms, 2 extra gear boxes, 2 extra differentials, a set of turnbuckles and the ends with the balls in them, and a sterring/servo saver assembly. You can also buy an extra set of shocks, or just fine the shock rods, and shock rod ends. those tend to be the piece that bends or breaks most often.
Not sure if they can ship to your address or not, but towerhobbies ships to canada and the us as far as i know.http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGSDB&P=7How do I get to the RPM website?
I haven't found it yet.
Thanks for your reply
