Vorteks Looking for guide to turn Vorteks into Granite
RubberRolling
  2. Vorteks
Hello everyone,
I was wondering if anyone has come across a guide on which parts to use for a Vorteks to Granite conversion. I have scoured the internet and Youtube and haven't been able to find a complete guide to make it easier for a beginner to understand parts compatibility etc. If you have come across something like this please post the link!
Thanks in advance
RubberRolling
  2. Vorteks
Granite tower, body, shocks, bumper and wheels. That’s about it.
I see so if I order those stock parts for they will just swap right over? Thanks
Why not just buy a granite and leave the vorteks alone? Then you can invite a friend to play.
Just did that actually, received Granite today and realized how much more capable it is off road. My son and I will be bashing together and it seems that the Vorteks gets high centered on things that the Granite barely notices.
Also if you do shock towers do you need to replace the steering arms etc?
Velodromed
One to turn, two to burn.
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Vorteks
  8. Voltage
  9. Infraction 4x4
Both have short arms so all good there. I simply put a granite shock tower on mine so I could run the same shocks front and back. Turned out very nice. Then I put long typhon arms, MX28s and it really rocked. You could just throw on granite tires and it’ll make a big difference.
RubberRolling
  2. Vorteks
Ok thanks for the help!
quiznatodd bidness
Northern Colorado
Happy family bashing!
Do keep in mind, if you put on the granite tires, you might also want to gear down the pinion. Vortex’s comes with an 18 and 20. Granite runs a 15t. Don’t want to overheat or prematurely damage the plastic gears.
FireDrake001
  1. Typhon Mega
Hello everyone,
Thanks in advance
Honestly I do not see why you would want to change it. There are so minor differences that it is mostly tires, body and bumper. The tires and body are what make the difference in these two.
RubberRolling
  2. Vorteks
Good point thank you
Velodromed
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Vorteks
  8. Voltage
  9. Infraction 4x4
The pinion is metal and the stock spur is nylon-plastic. It’s fine. Even with a metal spur it’s fine. When it does wear out a Robinson racing pinion will last the life of the car. Stock 3s granites come with a 15t pinion. You can pretty much go to a 17t before heat issues with the stock motor begin.
