Mojave 2WD looking for the battery door pin
jimbo74
  1. Mojave
Have no idea what happened to my battery door pin. Is there any way to find a NOS or used one? If not, I'll probably end up making one out of a piece of aluminum tube and just run body pin on the other side too
I tried ebay, but only found pins for other models that have a D shape on one side of them, pretty sure mine just had a flange at one side
If you have an original 2WD, the pin should be the same as the rest of the 2WD lineup. At least, every version I have owned (Fury, Raider, Raider XL, Mojave and Vorteks (I had a Granite for maybe 2 days before I made it a LWB monster Fury), used the exact same pin, whether it was the original 2 piece chassis or the later one piece design. All the Mojave was was a Fury that was more set up like a higher ground clearance 90's desert truck.
Edit: Look for part# AR320203. It's the only way to get that pin. And, I stand corrected. The all plastic SWB early one piece chassis had a different pin than the LWB vehicles, for some odd reason. Something I also didn't think of, the forum has ALL of the original manuals, for each of the different models, still available for download.
