Senton Looking to upgrade shocks and tires on Senton 3s
The prolines are for the slash .. I used the rear for the slash on the front of the Senton and the extra long shafts on the back which also comes with 2 sets of duel springs
I use the same set up on my Losi Rock Rey. I would have thought the XL's would be too long for the rear of the Senton.
Any chance of part numbers..??
Thx???
These are the ones he is running up front (rear Slash shocks): https://www.prolineracing.com/performance-parts/power-stroke-shocks-rear.asp
And this is what I think he is using for the rear. He said XL, but maybe he meant XT: https://www.prolineracing.com/performance-parts/powerstroke-xt-shocks.asp
I run these same shocks on my Rock Rey. The are expensive. I’m not sure how good of a fit they would be for a Senton. The rears would definitely be too long and the fronts a bit short.
Hi there i just upgrade my shocks with gmade XO aeration model (103mm,113mm) the fit perfect the fronts are the same as stock 103mm and the rears are only 3mm shorter 113mm vs 116mm stock but they fit with no mod. The only thing you should keep is the stock shocks spings as the gmade's are too soft. I also install Louise uphill 14mm hex tyres the car look and feels great and i'm waitting to try my new set up!
Hi menios,
Nice set up and thanks for the shock info.
PL
There is only one shock that truly fits and its the typhon BLX 6s shocks.
I have tired the Big Bore shocks and they will not fit.. Stock or the Typhoon 6S shocks AND good luck finding a pair.
Arrma does not sell them but there is one place that does. I would image you have the same ones I have that are stock ones from Arrma that are made out of plastic!
