Have you seen much of a difference since swapping for the other one out the box?My pinion came loose the second time I drove mine and slid twords the motor and was hardly meshing with the spur at all. I tried tightening it but it wouldn't hold for more than 2 pulls on the street so I swapped to the other pinion that came in the box and have had no problems.
.me too,its loose on The shaft but didnt come all the way off,it slides back and forth.so im ordered a 13t tekno gear and somMine was really hard to get off. I had to heat it and pry it off. I'm surprised yours came off.
That sucks!!I have tried getting mine off but doesn't move at all. Now I have snapped the removal tool inside the screw. Looks like I'm going to have to drill it off
Thats supposed to be the speed gear for street instead of dirt right?Have you seen much of a difference since swapping for the other one out the box?
Sounds like i got lucky but sucks i had to do this anyway....Mine was really hard to get off. I had to heat it and pry it off. I'm surprised yours came off.
They say it's for street only but that's to cover there own backs. I no plenty of people on here that off road with that gearThats supposed to be the speed gear for street instead of dirt right?
Does it make a difference in speed with the other pinion or what?They say it's for street only but that's to cover there own backs. I no plenty of people on here that off road with that gear
Nice might as well try mine also thanks.Yeah it seems faster for sure. And being that it's a bigger gear I had to re mesh them and I think the mesh was a little on the tight side out of the box. After putting this gear in and re meshing it seems to have more torque. Doesn't make much sense to me why a top speed gear would give me more torque hense why I think it was meshed a little tight from the factory.
Well thats some good knowledge thank you much .i will have to get a motorfan asapEach tooth you go up on the pinion is worth roughly 4mph increase in top speed so I it's a noticeable increase in wheel speed when going from a 12t to a 16t
You can bash pretty hard off road, just check your temps every so often and keep the motor and ESC below 170f
When running backflip tires it's wise to install a motor fan if you plan on running higher than a 15t off road (grass/dirt)
17t + motor fan is about as high as you can go with temps while running the backflips if you're pinning the throttle a lot off-road. Mid to low 160's by the end of a 6s pack for me
Same thing happened to me i stripped the screw too, got my dremil and had to grind off that tiny lip on the shaft, slid it right off...me too,its loose on The shaft but didnt come all the way off,it slides back and forth.so im ordered a 13t tekno gear and som
That sucks!!
