IwatchTV
- Granite
The Left rear drive shaft on my 6s Kraton exb keeps coming off.
When fitted it has 1- 2 mm of play in. Whereas the right side is fits very snug.
There no bend to the dog bone. The rubber piece that sits in the outdrive is still present and the out drive cups are in good condition
I've adjusted droop and even tried spacers on the shocks. But still problem it there.
The only solution I can see is to maybe stick a shim or 2 against the big washer that sits in the wheel hub. But is this likely to cause wear to the inside of the hub?
