Losi DB cage on typhon
Kingleo619
San Diego, ca
  1. Typhon 6s
It fits on a tekno easily...but this is on my typhon
As you can see the front fenders would need to be cut off for servo arm to turn, front body mount will line up, the rear shock tower you would have to drill holes. This typhon is stretched so hard to say...what length is the cage and 3s typhon
slick2500
Community Leader
ArrmaForum Fan
Solutions
6
Rapid City, SD
  1. Outcast 6s
  2. Senton 3s
  3. Typhon 3s
Yes it fits the Typhon 3s but you need to trim the side guards and make your own mounts.
I would not recommend using the method I used to mount the rear of the body, the aluminum isn't thick enough and it bends.
20200511_145654.jpg 20200511_145841.jpg 20200512_011354.jpg 20200512_005720.jpg
There was another member on here who did this at the same time I did and his method looked to be much better, I will see if I can find a link to the post.
Grimbles
Certified unintentional RC destroyer
ArrmaForum Fan
Solutions
1
Birmingham, UK
  1. 4x4-Mega
  2. Mojave EXB
  3. Outcast 6s
  4. Typhon 3s
slick2500
Community Leader
ArrmaForum Fan
Solutions
6
Rapid City, SD
  1. Outcast 6s
  2. Senton 3s
  3. Typhon 3s
