- Felony
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Outcast 8s
- Typhon 6s
Making progress on my DBXL-E 2.0 build. Rebuilt all the diffs with Fast Eddies and put them in the cups too. Went with 200k F / 1M C / 100k rear. Badlands MX43 are drilled and ready to be mounted. DGI 1” extenders installed. Spectrum S9110BL installed. Unfortunately DGI sent me 2” extenders instead of the servo arms (still no luck getting them to make it right). RadioLink radio installed. Losi aluminum chassis braces and servo saver installed. Body panels all shoe goo’d. 48T spur installed (took a bit of grinding to fit!). Next up drill holes in the Xtreme racing CF ESC mount for my XLX2 and solder on my QS8 connectors. Then just waiting on the 1100kv motor! Have the castle 2028 motor fans but just ordered the Integy cooler instead. Think I’ll start with an 18T pinion. Probably going to order some SMC batteries at some point here too. So pumped for its maiden voyage!
