I know there isn't a way I just plugged them into the extra ports lolDid you try rebinding like I posted above? That would tell you for sure whether it is the esc or the radio system.
There is no way to use three channels on a two channel system. I assume you are using the aux port on the reciever for something? What??
Not sure about this yet but I think it might be the compatibility with the castle esc... Happens to me but am going to try the tactic they sent me good luck man hopefully a new TX and rx might be a fix but I have to fix a lot of things before I can update this about a different tx and rxOK. Finally got the motor wiring fixed up on my Fury rebuild. Down to one problem, and that is that I am losing Radio/Receiver connection very quickly, and occasional glitches (within first couple seconds after picking up connection again). The car goes unresponsive in less than 50 feet, and some times I have to get within 10 feet before it responds again. Fresh batteries in the transmitter, antenna looks good, rebound the transmitter and receiver twice. This truck had amazing range with all the stock electronics, but I let the magic smoke out of the stock motor, and went through the whole model and installed a Castle Sidewinder 3 ESC and a Turnigy 3900Kv motor. And now that it is finally back together, the radio system is giving me fits. Any other ideas, before I contact Arrma and try and get the receiver warrantied?
I found that it didn't go as far as it was stock so after a while of pushing them to send me a new TX and rx I got the tactic which is still in the box and is waiting for the range testOK. Finally got the motor wiring fixed up on my Fury rebuild. Down to one problem, and that is that I am losing Radio/Receiver connection very quickly, and occasional glitches (within first couple seconds after picking up connection again). The car goes unresponsive in less than 50 feet, and some times I have to get within 10 feet before it responds again. Fresh batteries in the transmitter, antenna looks good, rebound the transmitter and receiver twice. This truck had amazing range with all the stock electronics, but I let the magic smoke out of the stock motor, and went through the whole model and installed a Castle Sidewinder 3 ESC and a Turnigy 3900Kv motor. And now that it is finally back together, the radio system is giving me fits. Any other ideas, before I contact Arrma and try and get the receiver warrantied?
Post some pics of your wire routing. More specifically, motor leads, battery leads, and antenna.
As stock I think the antennas come like that guess will have to look at mine too... But it seems to be that the castle systems don't like the stock rx and TX since I am one of the three people who have issues with the stock rx and TX when we installed the castle systemHmmm, no red flags that I can see. Not sure it would make a difference, but I would try a taller antenna and routing those motor wires lower and through the bracing for the rear shock tower. Anything conductive between you and that antenna is bad news (those wires, your shock tower brace). High current by it is also not a great idea and I am wondering if your body pushes those motor wires down next to it?
While I am nit picking your antenna, those antenna tube caps with the wire bent over and coming out is not something I would run. To much potential for damage to the wire where it is folded in half.
Apparently castle says that the rx and TX are at fault but Arrma says send the esc back to castle lmao and I already sent my Rx and TX in (waste of money so don't do it) and they said "no damage" so I have been stuck on this issue for quite a while now lolThat's why I'm reluctant to say it's the ESC, as this is the 4th SW3 I've installed, 3 in Traxxas Stampedes, one of which has been moved to a Raider, and all work fantastic. The only difference is this one is using a Turnigy motor rather than a Castle motor. But I'll see what I can do to move the wires around, or maybe swap in a castle motor and see what happens. Maybe source some different wire for the leads. I wasn't able to find silicone insulated wire locally, and used PVC insulated wire from Lowes.
