Diem Turner
Yes...I have a Premium Member
Rig of the Month Winner
https://scriptasylum.com/rc_speed/top_speed.htmlThank you for the information. I might be using a crappy speed calculator since it only asks about my gearing and diff gearing, motor kv, and tire diameter. This is the data from the pass itself:
-Current: 305.8 amps
-Max RPM: 39,438
-Voltage: Min 27v
Avg 32.9v
Max 33.8v
This is the speed calculator I use and, once you get voltage sag correctly dialed in, it's really accurate. One thing you don't want to forget is when inputting motor KV, start at 80% of the KV value of the motor. It will probably require a little bit of tweaking but that should get you in the ballpark. The KV rating of all motors is freestanding, not accounting for load. A 1650KV motor is realistically closer to 1320KV and so forth.
Here's a typical calculation for an Infraction V2 with 2.8 ratio diffs and a 2400KV motor.
Just for the record, this car did indeed max out at 122mph.
