firstrctruck
- Nero
during session. What should I check?
There intactha ha...typically. ..the servo rod screw comes out...
flip it over...turn it on...turn the wheels...see if you can see if the servo link is disconnected. ...
send pics...and we can give more...
..There intact
Here's a pic
Wasnt raging on here either. This sucks
Nope nothing. The black and red wire ?..
ok...so now check tightness of servo saver...and servo wire connections...to make sure they didn't come loose ..
do bench check is steering...meaning...turn on..see if you hear anything when turning the wheel on the transmitter...
There intact
Here's a pic
Do I need to take it apart?
...yep...trace back that white red and black wire from the servo to reciever box...Do I need to take it apart?
Looks right
I got a fluke could you walk me threw it?
This is the none brain. I'll try bind a few more times. Emailed arrma (disappointed)So I'd rebinding trans and reciever didn't work...then something is wrong.....hmmm...
do you have another rc to check the servo?..
if throttle control still works we can surely say it's the servo...
are all the other channels working?..meaning I assume this has the diff brain...so do you hear any of the other servos working when you go through the diff lock settings...
starting to seem like the servo may have taken a dive ..
the rebinding process is in the manual...really simple. ..try binding more than once...sometimes it takes a few tries...
Thanks again
What's the recovery box?well don't give up...but yeah that sucks...
alot of times on these ready to run cars ..the servo dual rate isn't properly adjusted...and it only takes a few turns to full lock to fry one...
one more thing to check...open the reciever box and check those connections.....
I had that open already to rebind right?
Burned servo. Thx. Back up
