- Infraction
- Limitless
- Kraton 6s
I just lost throttle and steering on my infraction v2. Still have control of the hand brake but thats it! Any advice on how to fix this would be much appreciated.
They are having major reciver problems. Do you have 1 you can swap in
Not really, probably just take it to my local shop to testThey are having major reciver problems. Do you have 1 you can swap in to test?
No crash at all just did a couple donuts and came to a stop and then nothing workedWarranty will cover as long as it isn't from a crash or anything lol
I have only had this thing a month and have maybe driven it 5 times. Is that normal for them to crap out all of a sudden?Yeah the fact you lost all but 1 channel I would say reciver
Just tried it again and it went through the beep cycle twice?... and then the final high pitch beep never happened and I turned the steering and it worked but the steering stayed at full lock to the left even after I let go of the remote.No but they seem to have gotten a big bad batch.. unfortunately any and all electronics are that way at timea
Ok so I disconnected both servos and I got throttle back, then connected hand brake and throttle and hand brake work then connected steering servo and lost throttle and steering doesn't work so does that mean the steering servo is bad?Disconnect both the steering servo as well as the handbrake servo and see if you have throttle. Then plug the steering servo in and see if you have steering and throttle.
The steering servo is an Arrma servo while the handbrake servo is a Spektrum - the Spektrum servos seem to take down the electrical system when they fail. I wonder if the handbrake servo died since Arrma doesn't really do any travel endpoint adjustment on that thing and just let it crank against the disc brake.
