Love for the Bearings
Steve B in Vegas
+11mm Kyosho Hubs on the Mojave.
Las Vegas
  1. Mojave EXB
  2. Senton 3s
So in our lovely desert climate, the fine dust really does a number on bearings, and my passion for racing around wet soccer fields doesn't help. Even with the sealed bearings, they are still showing drag much sooner than I would like. So I have been experimenting with a cleaning technique. Works better on the standard bearings than the sealed F Eddie bearings.
So I start with wiping down the bearings after a dirty run. Then I toss them into a small wire basket. Into my ultrasonic cleaner with 1 part Simple Green to 2 parts distilled water. Run with heat for 30 min. Remove and toss into plastic strainer and blow them out with an air hose. This takes a bit of time to do right. I end up holding each bearing in the middle and getting it spinning with the nozzle and hit the sides.
From there I drop them into a plastic container with Lock Ease. This is a graphite suspension. Let them sit for 10 min, and during that time shake them around a bit. After that I pluck them out with forceps and drop them on another wire basket to drip dry. After 15 min, I wipe off the remaining and reinstall them into the car.
So far I have about a 80% success rate. Some bearings are damaged inside and the steel balls no longer spin freely, and they can't be salvaged.
I have three full sets of factory bearings and 2 full sets of FE bearings, so as they tighten up from use, I just toss them into a plastic container until I have a good number to clean.
I have tried to remove the plastic cover on the FE bearings, but I destroy half of them so I stopped messing with that.
Anyhow, figured it might be of some interest to you guys.
s
That’s way to much work after a bash. My solution is don’t clean your car. I never clean my car and every bearing on my car is caked with greasy dirt and it prevents any water sand dirt to get into my bearings
2 years and still run my stock bearings I also drive it in the snow
You need to remove the rubber seals. I see you didn’t.
I clean bearings in my ultrasonic cleaner too. I fill cleaner with water remove seals from bearings and put a few ounces of solvent into a glass and put the glass into my cleaner. 20 min later remove everything and spin dry all bearings and pack with red and tacky. Good for a long time.
I gotta work a bit more at not damaging the seals when I remove them. I might see if I can find replacement source of seals and order them in bulk.
That would be awesome.
Is it possible to pack the bearings with grease to minimise ingress?
I always do. Only ones I don’t is motor bearings. Any of the other bearings it doesn’t hurt them.
I use a good pick to pop the seals. Exacto knife works too.
ordering replacement seals? Good luck with that. The exact sizes bearings from different manufacturers have different seal sizes.
I will chase it down.
For sure, but I will hide behind my corporate engineering mask and see if my suppliers can dream something up. If they are coming out of China in bulk, it can be found.
A pack of 10 bearings is under $10 cad us it worth it?
It's not about the cost for me, it's about the details. I'm not a fan of throwing things away just because I didn't want to service it. I also detest paper plates, and I'm that guy with his personal coffee cup at starbucks. Maybe I'm just wired wrong. I also work in a machine shop, so tools and getting into details is a culture for us.
Oh don’t get me wrong I get it! I find pleasure in cleaning up a bearing and repacking it. I’ll squeeze all of the life I can out if it. Too bad there wasn’t a “trick” to removing the seals. That would solve our problems.
Yeh i cover my diff bearings in thick marine grease to mitigate water and debris ingress. It does also attract a lot of dust, but I presume its only on the surface and not making its way into the bearings.
Is there any value in using industrial bearings? I’m thinking of ordering some SKF/FAG/NTN sealed bearings for key applications like the drive shafts/diffs, and wheel hubs. Haven’t really seen anyone use industrial bearings in their Arrma yet, but i haven’t been here long :p
