Lovestrickens Kraton
3d-rc.myshopify.com
Eat,sleep and breath Arrma
Hospitality Award
Michigan
  1. BigRock 4x4
  2. Granite
  3. Infraction
  4. Kraton 8S
  5. Kraton 6s
  6. Notorious
  7. Senton 6s
  8. Senton 3s
I guess I will make a build log at this point.
*Installed parts*
COUSTOM BODY
HOT RACING PARTS
Front hubs
Rear hubs
Dust cover
Wing caps
Steering servo brace
All 5 hinge pin blocks
Front and rear diff housing and cover
SAVOX
SW 1210
RPM
Rear mud guards
Front skid
Rear skid
Front bumper
Front arms
Rear arms
Rear bumper
ARRMA
Wheelie bar
All 3 EXB diffs
TURNIGY
Light control kit & led kit
RADIOLINK
Radio
Reciver 6ch w/gyro and abs
MISC
100wt shock oil
60,000 Front diff
500k Center diff
30,000 Rear diff
M2C
Bladderless shock caps
Chassis
Akerman steering plate
Front tower
Rear tower
Front chassis brace
Rear chassis brace
Shock stand offs
Rear tower brace
HOT RACING
17mm hex caps
HOBBYWING
MAX 6
5687
Coustom
Esc fan mount
Wing brace
Max 6 mount plate
PPS
Motor mount
Center diff mount
Center diff top plate w/ roll bar
Saga
30 tooth pinion
Bearings
Full boca silicone sealed ss set with hybrid motor bearings
She is cleaned up for now so I can work on her. But you better believe she is no shelf queen. Already have a new set of copperheads for when she is done.
Who am I kidding these projects are never done. Motor combo next. I am holding out for a castle.
? good luck! It’s been awhile since I’ve watched a build thread from the start (if this can be considered a start lol) im excited!!
The fronts don't ballon. Not reverse lol. I like to slide the ass end around through the gravel pit. Gives it more of a posi feeling in the rear end... the million weight center kills the ballooning enough.
For the power the kraton or any 6s makes. Some times to turn sharper you need that back end to step out a little on bigger vehicle. If it was a buggy on the other hand yes you want them to be more front wheel drive as they are able to to have more lock to lock steering control
With 1m in the center I can confidently say it’ll be hard for those front wheels to ballon lol... I like running a similar setup to him actually.
Yeah only time they ever balloon is over 40ish mph even doing wheelies they wont balloon.
To be honest I was at first as well. Now that I did it once it's a piece of cake. If you need assistance don't be afraid to ask. The setup while installing it makes it easier to move over I mounted it to the center brace so I can just plug it in and remove it easily
Just ordered the power plant. Should be in the next week or so.
M2c parts just shipped will be here in next 3-5 days
I do too 1M center 60K front, 30k rear (used to be 100k front 60k rear, but I like more steering) and my fronts can still balloon. Although the 4985 hooked to my Max6 can still give any diff a workout??
Just picked up all the shock rebuild pieces for the m2c shock caps
Well parts arrived today. They don't need it but I am going to rebuild the diffs while I am at it as well. Christmas came early for the kraton.
Everything that has come off so far.... this is taking a while lol. I still have to rebuild the diffs , m2c Ackerman, m2c shock caps and rebuild, rpm arms I am going to keep off when they get here. I am worried about winter breaking them plus I have 3 stock set to use up. Need to run to hobby store tomorrow for wire to lengthen the motor to esc connections. I am putting a jumper in so I can remove motor like stock blx system. She is getting there. I am also going to pick up another bearing set to replace everything while I have it open tomorrow.
This is where she stands currently.
She is 95% done. All shocks and diffs are rebuilt. All the wiring is done. I did however have to slot a couple stuck screws. And a shock tower stand off literally snapped in half like butter so need a new one. Looks like I am going to the lhs tomorrow for last couple things... I hope lol. She has been down over a week now waiting on parts and what nots... the other toys are just not the same . You can only speed run so many times before you get bored lol... well this is where she stands. She isn't much but she is me. And no one else has one like her lol.
She went on her maiden voyage today. Unfortunately I think my reciver got pinched or something along those lines. She only has about a 30 ft range. I know it's the reciver because the headlights go out at same time. It isn't the radio because I was just using it on speed runs and was working flawlessly. Look like I have more stuff to buy.. she might be done by spring. ?
Oh btw a 23 tooth pinion makes this max 6 combo warm fast fyi. Going back to the 20t to see how she does
