I never had the vxl6s esc, only the mxl-6s esc and it died on my second 6S run when I moved it to the 2.0 chassis after 2 hard years of 4S in the v1.
@Ari33 I have seen enough posts about Arrma 6s cars with 2200kv motors getting hot, that I can agree that it MIGHT get too hot. As you said running the 4000 mAh LiPos hopefully help keep the weight down enough.
Ambient temps and driving style will ultimately be the deciding factor. 150 to 200kv although seemingly little can make quite a difference in heat and rpms.
I just meant castle escs in general. That’s the only time I’ve had an mxl. All other times were actual castle mamba monsters. Truck currently has a mme out of an xo1I never had the vxl6s esc, only the mxl-6s esc and it died on my second 6S run when I moved it to the 2.0 chassis after 2 hard years of 4S in the v1.
