With your run time being so short I suspect your batteries aren't drawing at the same rate causing LVC to come early. You should mark your batteries so you can tell them apart and try plugging them in the opposite order.
As far as your truck just stopping is concerned sometimes it's hard to tell when your truck is in first stage cut off. If you're not raging your truck it may seem as though it's driving the same.
