Notorious Lower A Arms Replacements
thatRARAguy
  1. Talion
Hey everyone,
my brother's v5 Notorious just broke it's lower A arms. I thought it was the same ones for the Kraton, outcast, Talion, etc. It turns out that they're the EXB ones, 330654 not 330249. Can he not run the other set? The EXB set is extremely hard to find currently. Could he run the RPM's? I thought the Outcast and the Notorious were the same truck just different bodies
Yes you can run the RPM arms just need shorter pins that hold the shock in the arm as they are too long on the v5 for the RPM arms. I would think a v4 set of arms would be the same thing as the new EXB/v5 shock pins are longer
Thanks!
Be sure to get mushroom style droop screws if it doesn’t already have them.
Your droop screw in the rear is gonna be right on the edge of your chassis.
Yep sorry forgot about that also, good catch bro!
