Lubricant thoughts?
Matt Hotelling
Senton
Lubricant thoughts? Dry lube good for plastic only? Any use? What would I use others for?
Clubin
I spray everything down with wd40 other than that. Nothing. I clean and regrease bearings periodically. Lube sprayed on anything else either attracts dirt or doesn’t do anything other than make a mess.
Matt Hotelling
Senton
Cool thanks! The dry lube product does work pretty well and doesn't attract any dirt on all the suspension. Just making sure it would work. For anything else I don't use it on bearings or anyting.
Anything
Can you use the white grease on the spur/pinion?
slick2500
Will work for beer.
Staff member
Rapid City, SD
Outcast 6s, Typhon 3s
Anything
The only one I would use is the WD40 dry lube, no use for anything else.
Harlon Arrma 6s BLX 6
RcRookie Arrma 4x4 4
Mike-NLD Tools 9
Matt_060983$ Arrma 6s BLX 12
