Matt Hotelling
- Senton 6s
Lubricant thoughts? Dry lube good for plastic only? Any use? What would I use others for?
Cool thanks! The dry lube product does work pretty well and doesn't attract any dirt on all the suspension. Just making sure it would work. For anything else I don't use it on bearings or anyting.I spray everything down with wd40 other than that. Nothing. I clean and regrease bearings periodically. Lube sprayed on anything else either attracts dirt or doesn’t do anything other than make a mess.
AnythingCool thanks! The dry lube product does work pretty well and doesn't attract any dirt on all the suspension. Just making sure it would work. For anything else I don't use it on bearings or anyting.
The only one I would use is the WD40 dry lube, no use for anything else.Cool thanks! The dry lube product does work pretty well and doesn't attract any dirt on all the suspension. Just making sure it would work. For anything else I don't use it on bearings or anyting.
Anything
Can you use the white grease on the spur/pinion?
Damn who told you. ... ????
Tin Man knows bestDamn who told you. ... ????
So does Tin Man mean just... uummm... nuts and bolts...Tin Man knows best
