Brushlesspower83
Thank you Mitch looper "M2C" for the chassis braces. awesome fit, very nice finish. looking forward to purchasing lightened speed chassis next.
Use the corresponding hole as your pilot hole take the 4 mm drill bit that Mitch provides drill straight down with top plate already mounted makes it easier.Hello,
I read that for the front brace you will need to drill the steering top plate, how did you do it ?? the problem that I find is that you have to drill out in a hole that has another one just next to it, so did you drill just in the hole or just a little bit in the side to keep the distance with the other hole, I do not know if I am explaining my self very good.
Best regards
ya bro super easy my guy... mitch includes a sharp drill bit. just drill out and install. I took my steering link out so I can install with the nut on the bottom not the top if that makes any sense it was easier for me to just remove the steering links. this way you have more room to work in.Mine on way,don't you just drill out exsisting hole already in plate. Pc a cake.
