M2C Hinge Pins - Lube or Dry?
arrmigo
Australia
Hi All, wondering if you guys keep your hinge pins dry or lube them? Not sure whether rust prevention with lube is better or keeping dry so it doesn’t attract dirt & dust
Cheers
Any dry lube that specifies it's safe for plastic and metal. A lot of these dry lubes are a PTFE based spray, which is what I use
Very fine clay terrain ( think baseball field) will do a number on dry hinge pins. They wear and start to bind more and more to the point they squeak very loud.. I will use a Dry lube after a good cleaning. Barely a drop I smear on to them. Dupont Chain Saver/Teflon. It wont attract dirt "as much". And I can get some more life out of the hingpins and arms and Rear hubs this way . But they don't need them when new and through most of their life IMO.
Dry lube only if anything. Very very little.
