Ricerocket00
- Talion
My first time ordering from them, but lots of people on the FB Arrmy group have recommended them. I ordered my chassis from the M2C site, too.
FYI....Both Kraton and SWB Outcast/Typhon/Senton chassis are back in stock along with a new product for the Arrma 6s line
tool steel hinge pins
https://www.m2cracing.com/product.sc?productId=944&categoryId=123
Arrma 20% off coupon code: M2CCOUPON
I assume the hinge pins are $11 for a pair? Shows 2 in the picture, but wanted to be sure before ordering. I messages Mitch on FB Messenger, but no answer.
So far mines 14.6lbs with hrb 6s 5000 in itOh yeah... I ordered one 2 days ago . Pretty soon my Kraton will weigh like 25 lbs lol. I also just bought a max6 ESC to handle the hobbystar 4092
Well at least the wives can use them as dumbbellsSo far mines 14.6lbs with hrb 6s 5000 in it
That's a nice looking rig! I just ordered a set of hinge pins and droop screws from M2C. Waiting on the motor mount too. I'm an equal opportunity purchaser, though. I've got a set of JBIRC 20mm extended hexes on my Kraton too.I got the M2C chassis installed on my Notorious and I removed the Markhor top plate. I think between the chassis and the Voltage Hobbies braces I will be good to go!
View attachment 31121View attachment 31123
And one picture of the green shock towers, LOL
There still is one weakness that I’ve mentioned to the good people @ Voltage Hobby and it has nothing to do with them. The rear brace / wing mount design is a fatal flaw. That brace should be directly mounted to the bulkhead, it could be made of adamantium won’t matter, it’s bolted in between plastic allowing too much flex if you do big air. Hopefully the M2C chassis (I’ll know tomorrow) eliminates the side to side flex.
Would an HR rear diff bulkhead alleviate the issue?
Yes..... see the aluminum part that is mounted to the upper bulkhead? It isn’t connected to the brace at all. It is close but not connected. That aluminum wingmount basically serves zero functional purpose. Now you see how the wing mount arms hold the top of the brace in place. So basically flexible plastic is holding an aluminum brace and nothing is holding the load from the upper bulkhead.
