m2c typhon chassis added to cart, But shock tower what’s y’all thoughts between the two
i noticed the jbit chassis doesn’t have side guard holes or I’ll get that those side guards allow me to put my batteries side by sideI use JBIT towers and chassis..... I am very proud of this combination... hitted , crashed , dismounted but not brake or bented.... ( remember my crash at 50 mph>0 mph against as tree!!!
my 8 mm jbit are OK ....M2c racing shock towers are thicker in certain areas vs the Just bash it shock towers! I already bent my Just bash it 6mm shock towers and i WAS barely jumping that high! I already ordered Mitch's Chassis and a set of his shock towers for my #v3 #KRATON
I gave mine away and bought the M2C towers. That pretty much tells you where I stand ?my 8 mm jbit are OK ....
One more time. If you added an M2C Typhon light weight chassis to your cart (not even sure they're available yet) than understand that it is not designed for bashing. The Outcast chassis is the exact same as the Typhon, and the Goliath Outcast chassis is the one you want.m2c typhon chassis added to cart, But shock tower what’s y’all thoughts between the two
so this the chassis you talking about right or does outkast has its own type of chassisI use JBIT towers and chassis..... I am very proud of this combination... hitted , crashed , dismounted but not brake or bented.... ( remember my crash at 50 mph>0 mph against as tree!!!
That's the right one. The only reason I brought it up, is because when you click on Typhon from the drop down menu at M2C, no chassis is shown. Wasn't sure if you had a lead on the new Typhon racing chassis that they are introducing. You won't be disappointed.so this the chassis you talking about right or does outkast has its own type of chassis
Ok coo appreciate your responseThat's the right one. The only reason I brought it up, is because when you click on Typhon from the drop down menu at M2C, no chassis is shown. Wasn't sure if you had a lead on the new Typhon racing chassis that they are introducing. You won't be disappointed.
Not the same as any of the others. Typhon towers are not interchangeable with any of the other 6sOk coo appreciate your response
One more thing does the typhon shock tower the same as the other arrmas the typhon ones look all Little or just get typhon towers
Not available yet to my knowledge mate but was only on there the other day ? i believe it's still undergoing testing ?That's the right one. The only reason I brought it up, is because when you click on Typhon from the drop down menu at M2C, no chassis is shown. Wasn't sure if you had a lead on the new Typhon racing chassis that they are introducing. You won't be disappointed.
