I am on a mission to mitigate some of my Kraton's chassis slap on 1.5' - 2.5' jumps at my local outdoor track. When bashing I could care less about chassis slap as I typically launch into a downhill grass landing, however, running around a track meant for 1/8th scale buggys exposes horrible handling characteristics of the Kraton when it slaps. My rig is a V4 BLX with EXB towers, braces, M2C chassis, and hinge pin mounts...so heavier than stock. When at the track I run with 1/8th scale truggy proline wheels/tires (so fun to be gripped up with 6s!). When landing some of the smaller jumps on track my rig slaps excessively and often upsets steering into a corner or disrupts/delays smooth braking. I am on the hunt to mitigate this slap on the smaller jumps at the track to improve smooth handling characteristics.
Shocks are fully upright (outside tower position), preload is set so the arms are level, droop screws are all dialed, and here is the kicker...I am running Losi 100wt shock oil (1325cst). Still slaps from a 12" static drop and on some of the smaller jumps at my local track. I come from a downhill mountain bike racing background - suspension is hugely important. No debate #1 of any fork/shock setup is spring rate...period. The challenge with these Kratons is the limited spring options that are a higher spring rate compared to stock and the correct length. I have read all of the charts and info I can on this forum and the only option I have found seems to be identified by @East tactics. However... these look stiffffffffffffff. I am concerned running mega stiff springs and the proper weight oil to achieve adequate damping will lead to a rig that will handle like a rock. I ordered some but fedex lost my package. Does anybody have any alternative springs for the Kraton that are 15-25% stiffer than stock?
Stock:
Front -
Rate: 6.2 lb/in
Length: 85mm
Rear -
Rate: 5.0 lb/in
Length 95mm
MW Components (Century Spring)
Front -
Part# 12477
Length: 2.75in (70mm)
Rate: 9.5
Rear -
Part# 1631
Length: 3.75in
Rate: 10 lb/in
Since fedex lost my package with the stiffer springs detailed above I decided to test something else. I have a new set of m2c zrs shock caps and pistons. The typical installation details that the piston should be oriented with slot channels downward - this orientation slows the rebound stroke of the shock. I just had the wild idea to flip the orientation of the piston to slow the compression stroke of the shock. Finished the install last night but need to swap a bulkhead before testing at the track. All variables will be kept the same with the exception of the new shock caps and pistons. Same spring rate, preload/ride height, and oil weight Losi 100wt (1325cst). Wish the heavy girl some luck! I will report back once I run at the track and bash spot.
Stock:
Front -
Rate: 6.2 lb/in
Length: 85mm
Rear -
Rate: 5.0 lb/in
Length 95mm
Front -
Part# 12477
Rate: 9.5
Rear -
Part# 1631
Length: 3.75in
Rate: 10 lb/in
