Kraton Maintenance Supplies
Jas42182
Hello all. I’m new to the RC car world. Always flown drones and helicopters.
I purchased a Kraton few months ago. Was doing maintenance on it and wondering what brands of grease, suspension oil (and wt that should be used) and glue.
Thanks all
Notorious J
Newb speed runner, lifetime rc destroyer💣💣💣
ArrmaForum Fan
Solutions
1
Around the corner from 120 mph
  3. Kraton EXB
  4. Notorious
  5. Outcast 6s
  6. Typhon 6s
  7. Typhon 3s
I've been using Associated for dif fluid and shock oil, no complaints. You might want to read through the forums about grease or why not to use it. The only place people might use a good silicone grease, is in the dif case to lubricate between the pinion and ring gear. Everywhere else, like the pinion/spur and driveshafts dogbones/cvd's, a dry wax/graphite lubricant is recommended. Basically, it's ok to have the insides wet, but everything on the outside is better off dry. Hopefully, more members will chime in with specifics on which of those dry lubes they like best.
olds97_lss
Bash Break Repeat!
Dekalb, IL
White Lightning Clean Ride wax chain lube on all the external stuff (bones, cvd's, hinge pins, spur, etc), red-n-tacky grease on the ring/pinion.
Diff oil weights vary from person to person. I run heavy oil, 100/500/100 associated inside the front/center/rear diffs respectively. If I was on a track, would probably run 20/100/30 or something like that. Beings I'm on grass or concrete 99% of the time, I like heavier, it also leaks out less, so lower maintenance.
For shocks, I ran 1200cst or there about, but I'm changing back to 1000cst which is stock on the outcast. It's a bit bouncy on jumps and harder on shock ends/arms. Just learning to live with a flat chassis truck and chassis slap IS OK! I have to remind myself of that. lol!
ARRMAed & Dangerous
O.k. so ive been reading various posts on cleaning & lube h bought the two items to start. My foru question is where do I use each on? And Is the chain cleaner I bought considered a dry or wet cleaner I was unable to determine that? I did note that it does have the Teflon in does label that it repair repels dirt
37687 37688
Mr.Duke
~ Living The Dream ~
Community Leader
ArrmaForum Fan
NC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Notorious
  5. Outcast 6s
  6. Talion
  7. Typhon 6s
Use the Brakleen to clean all the old silicone off of internal diff parts.
For maintenance pull all the guts out of them and put the parts in a plastic bottle. Spray a couple ounces of Brakleen in the bottle, put the cap on and shake/agitate for 4-5 minutes.
martysmith223
for all the people using red and tacky grease have yall noticed any issues with it making your plastic diff case brittle or is it eating at your gearbox case? .. its petroleum based grease you don't want patroleum based grease anywhere near plastic from my experience but iv seen alot of people still recomend it on here you need silicone or synthetic based grease just throwing that out there for those that don't know
olds97_lss
Bash Break Repeat!
Dekalb, IL
I haven't been using it for long. Just recently put some on my outcast and I think my stampede 4x4. Up until now, I used whatever napa had for general purpose axle grease and never noticed any issues. Other than it didn't stick to the gears very well. The red-n-tacky seems to adhere better.
martysmith223
yeah man no doubt it's good stuff I'd just keep an eye on what it does to the plastics
SrC
RC is a lifestyle choice
Solutions
1
Queens, NYC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Outcast 6s
Yes I agree completely.
martysmith223
I hate saying or or throwing it out there to people that are using it hints why I asked if they have noticed any issues... some plastics hold up to petroleum alot better than others ... so if it don't cause any issues I'll try it ... I may get a busted gear box case and slab some red and tacky in it and just test it out myself let it sit for awhile and take a screwdriver to it ... my theory is like other plastics the petroleum soaks into it and can make it easy for it to break at your tower screws or even your screw hole threads will be compromised... making it easy for the screws to strip out the holes ... thing is arrma may have thought about this and may have a better plastic that is safer to use with petroleum based grease and tbh that's some of the best lubricant you can buy
chevys10zr2003
ArrmaForum Fan
Minnesota, USA
  2. Senton 6s
  3. Typhon 6s
I think that @slick2500 has been using it for awhile. Have you noticed your plastics getting more fragile at all?
On a side note, I know lots of people have soaked A arms in WD40 to increase their flexibility. I'm pretty sure that WD40 is petroleum based. So I'm guessing that it has more to do with the type of plastic and I think that rc parts are more of a nylon material than a normal "plastic."
martysmith223
I'm guess this also and if so red and tacky is about the best stuff you can use
