DeathVirus
- Points
- 43
This is mainly to improve ON-POWER steering. Off-power steering isn't as important because you just tap the brakes and then power out of the corner. Also, this setup improves upon the braking performance.
The basic premise:
The basic premise:
- Lower rear camber link
- Reduce rear negative camber
- Reduce rear toe
- Add small amount of front toe out (1 degree is plenty)
- Softer front springs/shock oil
- Stiffer rear springs/shock oil
- Lengthen front camber links
- Lay down front shocks more than rear
- Add a little weight to front
- Softer front tires than rear tires
