Mama Monster stuttering
Thread starter #1
Ggradtech
Likes
Talion
I just installed a Mamba Monster X ESC. I tried to throttle test the Talion, and it just stutters like crazy without any acceleration. I checked the Castle Link setting , tried a few different ones, timing, etc. Nothing has changed this. Also, the ESC doesn't "chime" when I first power on the ESC. Any ideas?
arrmaracing
Likes
100
Sydney
Fury, Kraton, Outcast, Senton, Talion, Typhon
Is that the sensored esc and are you running a sensored kotor with it. I heard the mamba stutters alot.
tjf
Likes
30
Canada eh!
Kraton
I use a mamba monster x and it is awesome make sure it is set to sensorless brushless setting may have to reverse throttle on stock radio and recalibrate esc also make sure battery connectors are soldered properly to esc
olds97_lss
ArrmaForum Fan
Likes
345
Did you calibrate the esc to your receiver?
I had an issue with my MMX with the castle 2200kv sensored motor, but it was due to me not plugging the wires in the right order and using the sensored cable. It would just vibrate angrily when I applied throttle.
Thread starter #7
Ggradtech
Likes
Talion
I'm thinking maybe the crappy Amazon cheap XT90 connectors are to blame. I can't really get the solder to really stick perfectly. I think maybe I have a cold solder joint. I'm wondering why I get no audible tone when I power up the ESC in the Talion.
tjf
Likes
30
Canada eh!
Kraton
if not soldered properly, will definitely cause grief also on startup if set for auto lipo, it should chime the amount of battery cells you are running
Thread starter #9
Ggradtech
Likes
Talion
Yeah, at startup I get no tones or chimes at all. I get servo control, but no audio confirmation.
olds97_lss
ArrmaForum Fan
Likes
345
Maybe it's in NiMH mode instead of lipo. Would be odd though. Or the LVC is disabled causing it not to do the math on the total voltage.
Thread starter #11
Ggradtech
Likes
Talion
I hooked up the Castle Link on my PC. Its set on The factory default of LVC 3.2 V and SmartBrushless so it should recognize the cell count of the Lipo.
olds97_lss
ArrmaForum Fan
Likes
345
Strange that it doesn't beep when you plug it in. What packs are you using? If I remember right, there is a setting in it that controls current usage. High for really good high C rating packs and medium/low for others.
Thread starter #13
Ggradtech
Likes
Talion
I called Castle and they think that the ESC is faulty. They are sending me a new one. Great customer service. I've had a lot of Castle stuff and never had one fail.
Thread starter #14
Ggradtech
Likes
Talion
I'm an idiot. I checked the solder joints and low a behold...... one of the motor wire ends was not getting a tight connection. Problem solved.
olds97_lss
ArrmaForum Fan
Likes
345
Nice. Did you solder it or did it come that way? I think my MMX 2200kv combo came all soldered up for the motor. I just had to put battery connectors on.
Thread starter #16
Ggradtech
Likes
Talion
No, the MMX (by itself) comes with 3 wires and the bullet connectors. You need to do all the soldering
paul_pl
Likes
3
Poland
Kraton
That's exactly what I've been struggling for a few days until I've discovered one of the motor cable disconnected ;)
Similar threads
