- Birmingham, UK
- 4x4-Mega
- Mojave EXB
- Outcast 6s
- Typhon 3s
Disappointing :/Just chop it off and join the wires together, castle switch’s have been junk since the day dot
I have owned 3 Castle escs over the years, one is still bnib and the other 2 the switches died within the first week of use.Just chop it off and join the wires together, castle switch’s have been junk since the day dot
Thanks for confirming. This was literally its first outing!I have owned 3 Castle escs over the years, one is still bnib and the other 2 the switches died within the first week of use.
Not sure why Castle hasn't found a different switch for these, you can find posts about bad switches across various forums going back at least 7-8 years.Thanks for confirming. This was literally its first outing!
Hobbywing it is. £6 off ebay. DoneNot sure why Castle hasn't found a different switch for these, you can find posts about bad switches across various forums going back at least 7-8 years.
If you have an old dead Hobbywing or Hobbywing rebrand just steal the switch off of that and wire it up to the Castle esc, you only need the positive and negative lead you can just snip off the signal wire, they are better switches anyway.
