- Seattle
- Granite
- Kraton 8S
- Kraton 6s
- Nero
- Talion
- Typhon 3s
So im running a MMX on my Nero w/ diff brain and also a Castle Link for programming and pulling data logs.
I've been trying to find the sweet spots for everything but I cant figure out the motor temp in the logging. The motor temp readings always start at around 1 degree F and spike around but only negative?? For example the last run I did the minimum temp was -55F and the maximum was 0. Is this a common thing that any others here have experienced? The ESC temps btw read normal data, starting around ambient temp and reaching about 150 on a long bashing or track run.
I emailed castle and they haven't responded yet. They're probably inundated with emails from the holiday sales.
