Kraton 8S heatsink and fan should work with a minor amount of modifications. There is also the Hobbywing C4 that might be able to stretch to fit.Just got a Max 6 combo to go into my kraton exb, can anyone recommend a good heatsink/cooling fan setup for the motor?
that makes sense!!! exact same size motor, any idea what size fan they take?Kraton 8S heatsink and fan should work with a minor amount of modifications. There is also the Hobbywing C4 that might be able to stretch to fit.
I believe both are 50mm fans. You can easily adapt them to dual 40mm if needed.that makes sense!!! exact same size motor, any idea what size fan they take?
I also picked up a Max6... motor diameter is 49 mm,C4 says it fits 44 mm. For suthers sake and mine,am I missing something?Kraton 8S heatsink and fan should work with a minor amount of modifications. There is also the Hobbywing C4 that might be able to stretch to fit.
It fits ... with some persuasion...
Ain’t nothin’ a BFH can’t fix...?hmmm - username fits.
i have one of these spare, how does it fit around the pin that sticks out with the body clip on the end? did you have modify the heatsink?It fits the 49mm can with some persuasion...
Never mind the fan cover/guard.. ?
The fins had to be ground down a bit, I also had to trim the end off the cage so that the pin could be inserted at an angle instead of vertical. See pic’s to understand better.i have one of these spare, how does it fit around the pin that sticks out with the body clip on the end? did you have modify the heatsink?
I like this better, might have to change mine. ?Or you could go without heatsink with mount from alza.View attachment 110353View attachment 110354
thats exactly what i've been hoping someone makes but i've never seen it!!! Where can i get one????Or you could go without heatsink with mount from alza.View attachment 110353View attachment 110354
Found it!!! much appreciated going to order it now!
Why not this? I realize it doesn’t have a heat sink, do you really need one tho?I'm just a bit of an idiot with a HW 4985 and am in search of a heat sink and/or fan mounting solution that doesn't seem to exist. I don't want to be "massaging" or "persuading" anything either. Is this the ticket for a ~50mm motor? Cheers
https://shop.alza-racing.com/en/uni...g-base.html?search_query=Fan+mount&results=54
