Mojave Max 8 2200kv heat sink and fan help please
joemonk
Upgraded to max 8 combo 2200kv could someone please recommend what heat sink and a good fan for the motor Uk based thanks
Give this a go 🤷🏼‍♂️
centro fans are good. I use the heat sink from bad touch breakers its a twin fan setup but the plastic fans don't last long (y)
+1 on the centro. Have a few that have held up. I've put a 35mm centro fan under the std blx 185 housing so I would imagine you could do the same with the max 8 esc and a bit of jiggery. Tried all sorts of mounts for the motor and they either slide around or break so I make these after seeing something similar on this forum and they work great.
