rccar4life
- Limitless
- Kraton 8S
- Kraton EXB
- Mojave EXB
- Talion
- Typhon TLR
Motors and Lipos V2 Limitless. Smaller Lipo Trays than V1
ARA320665 Motor Plate 40 Series Max. (OPT)
ARA320721 Motor Plate 50 Series Max. (STD) THIS IS IN THE BOX
ARA320722 Motor Plate 56 Series Max. (OPT)
MAX Lenght Motor fits in stock mount is 110mm / 4.33 in
TP motors 4070 will be too long ?
The motor+ cables ? How long is 4070 tp with cables ?
TP 4060 is 92mm long + cables, so this will fit offcourse
Do these 40 size TP run hot ?
Why have TP not made 45-49mm motors ?
I look at 150mph
Maybe
Run it Sensored with XLX2 ?
I can use it with medium size pinion, or have throttle max , about 90% in radio ?
to run it cooler ?
180mph with this motor RAZ Shifrin
150mph max is enough for me
Innovation RC did run with 6s 146mph with this motor
Lipos,
because everything is moved more to rear, are the new battery trays smaller in length?
V2 Battery Tray MAX dims L:150mm / 5.90 in x W:51mm / 2.00 in x H:70mm / 2.75 in
https://www.arrma-rc.com/on/demandw...dw22213b92/Manuals/ARA7116V2_Manual_MULTI.pdf
V1 Lipo trays are 180mm ?
V2 is 30mm less in battery trays ?
Most of my Lipos are 160mm +
Diffs maintaince V2 Every 10x runs 2h 30min
Diffs maintaince V1 Every 20x runs 5h
I look at 150mph
Maybe
Castle 1721 .5Y Sensored Motor - 2400Kv
is better than TP for me ?Run it Sensored with XLX2 ?
to run it cooler ?
Lipos,
