hello all. I don’t have a multimeter. Can someone tell me the voltage output of the fan port? I have broken 5 fans now. I’m going to try to cover with mesh and use foam to cushion. Can I buy pc 35mm 12v fans? Will they work?
I am having the exact same problem so good luck and let us know if you find a good fan and a way to stop breakageFan killer!!! @RxMonkey
I will. I tried putting window screen over the fans and used thick double stick foam underneath them. Several quit working (3/4 trucks). I kinda tossed them in a pile in my garage. I'm a little irritatated with them for a few days. Gonna let the sit a while. I'll come back to it with a clear head. I gotta figure something out. Trucks are tough as hell but these fans I'm breaking like every single run. Usually way before I even finish a pack. @Spar69! on the other hand has never had any fan problems.I am having the exact same problem so good luck and let us know if you find a good fan and a way to stop breakage
