biggman100
- Fury
- 4x4-Mega
I know this has been covered on here multiple times, but, i got lost going through posts, especially older ones before some of the new parts came out, so, i figured i would ask just for clarification about a few things im still not sure about. The first one is, if i only run 2S, do i need to do the BLX slipper upgrade? Will the HD 17T inputs work on 3S, or, would it be better to do a complete BLX input, slipper, and diff upgrade if i decide to run 3S? The biggest one though is, if i do the BLX slipper upgrade, do i have to also swap to the BLX motor mount (either the fixed or the adjustable one), or, will the MEGA motor mount work with a 2S or 3S setup?
Next question is about doing the Typhon a-arm swap. I asked this awhile back, but, the one question that never really got answered is, are the needed parts from the Typhon a direct swap to my Granite Mega, or will i have to do any mods to make them fit? I was told that i would need the lower a-arms, turnbuckles, and rod ends, but i thought the Typhon was 1/8, not 1/10, hence the confusion about it. Just to clarify, i'm not doing a full Typhon swap. I have an issue with my Granite rolling on its side in turns, and someone mentioned in another post about using the Typhon parts to make the Granite wider so it helps stop it from doing that as much.
