Welbus
Looking to upgrade my granite to 3s. What are your favorite esc and motors to use? Also, what other must-upgrade parts are there?
While you’re waiting for responses…there are some good vids and hints at the top of the 4x4 section that may help you. Also search the forum for threads as it’s a pretty common topic.Looking to upgrade my granite to 3s. What are your favorite esc and motors to use? Also, what other must-upgrade parts are there?
Are your turnbuckles a single plastic piece or metal in the centre?I believe it's the most recent, it was new when I bought it in March/April.
Can go down the rabbit hole of wanting to jump and hard-core bash and maybe not come back out. I did that. It’s great!Forgot the v3 megas still had plastic turnbuckles. In no particular order then, presuming you have a v3:
Others may chip in, all can be replaced as you break stuff but I would suggest sooner rather than later!
- 3s turnbuckles
- 3s slipper clutch assembly
- Mod 0.8 pinion gear
- 3s motor mount
- Carrier bearing and assembly for centre driveshaft
- More powerful Servo (ds3225 cheapish off amazon not a bad goto)
