Thanks. I have a set of stock driveshafts coming on Monday. I got a rock stuck under the rear at the ball joint and it mangled the plastic, so I was wondering if metal is better. Doesn’t sound like these are worth the $.Have heard they are not worth a $hit and don't last as long a stock driveshafts. Huge part of driveshaft issues is setting your slipper properly. I've ran stock shafts for months and only went through a set of rears when I tightened my slipper too much otherwise stock hold up fine even when I ran the 6s 4074 motor with a 26t pinion on 3s so
Don't buy them! Had the same exact type on my Rustler and they lasted three runs.Thanks. I have a set of stock driveshafts coming on Monday. I got a rock stuck under the rear at the ball joint and it mangled the plastic, so I was wondering if metal is better. Doesn’t sound like these are worth the $.
