Good to know. thanks for the tips ??
Use this. It works great. It really does hold like red but comes off like blue. Amazing stuff.
I also have HR diff housing and other little bits and they are great quality .
Why is it $12??Use this. It works great. It really does hold like red but comes off like blue. Amazing stuff.
Why is it $12??
I don't see it on any of the bog box store websites... ?Please send me that for $5? lol Just kidding but damn, I have so much blue threadlock on hand! I do want some orange though to try. I don't mind heating stuff up in the meantime.
But the Blue is about $6 and the red is about $7 in the stores, so $12 with shipping isn't terrible I guess.
Same.I really thought I pay $1. I still think it's cheaper in my store. lol
https://www.harborfreight.com/02-oz-removable-threadlock-96059.html
This is the exact one I use and never a prob. Same sh*t I put on the Noto v3 servo saver and still strong after a year! ?
I'd get orange immediately if I saw it though cause I think the hobby feels like *collecting as much as it is *RC haha
what issue do the Hot Racing ones have? What makes em junk? I see they normally cost more than the Arrma ones and I certainly don't have any loyalty to HR...just curious. There are HR parts I am happy with though...steering blocks, hub extensions, um, wheel nuts? ...so just those so far... I also remember seeing the German lady (that used to be more active here) on youtube having to re-finish a diff case because there was some binding but I think it was GPM she had to fix.
I had issues with arrma's 2 piece cups:
https://www.arrmaforum.com/threads/issue-with-the-arrma-alloy-diff-cup-seems-too-long.14517/
Ended up not using a gasket on the cap end and used RTV and red locktite on both ends as the blue wouldn't hold more than a pack before the screws would back out. With both gaskets the diff was just under 1mm wider than stock and I couldn't fit shims in to get good mesh on the ring/pinion.
As for the center, with M2C chassis, hot racing motor mount/front diff holder, I could feel tension on it when put the diff in. At that point, I was like f'it and bolted it all up anyway full well expecting the bearings to blow out on me.
I honestly haven't run it a lot as between diff failures/reshimming/removing gasket, breaking other stuff, I don't have more than a few packs through the center diff, so the jury is still out on it. If the rear gives me any more issues, I'll just go back to stock plastic.
Hot Racing AON1101 Aluminum Differential Carrier Case - 1/8 1/7 Ar i run them two 6 s rigs love ummm ijshttps://www.arrma-rc.com/part/ARA220050
Any concerns on this product? I don't recall seeing anything negative, positive, indifferent on the forum here.
Better, worse, same as Hot Racing quality?
I only had fitment issues with my f/r in the Hot Racing gearboxes, I actually had to run the diff I was going to run in the front in the rear and run the rear one in the front thankfully they both were filled with 50k oil, other than that they have been great.Those were priced in error and were the junk HR ones. I’ve either thrashed or given away all but one of the ones I bought. Haven’t used the Arrma ones yet.
You get almost twice as much 10ml for the orange vs 6ml for the blue from Permitex.Why is it $12??
How do you use the shims behind the planetary and still set the gear into the pin ??!! Blowin my mind !I have all my diffs repalced with the arrma aluminum. Works great and fits perfect. Make sure to shim it correctly. Also use orange thread locker on those diff screws. I forgot to use any thread locker on the center diff and the screw slippped out and chewed my center mount. View attachment 69423
That stuff is impossible to find up here.I never run out of that stuff. Still want to get some orange.
