Granite Metal Spur Gear for Granite 3S Brushed?
longlimb
Hey guys. I've searched around the forum and YouTube and I can't find where someone has upgraded their Granite 3S Brushed spur gear to a metal one? My sos keeps shredding his spur gear and I would love to upgrade to metal. Is there one available?
Are you setting your gear mesh properly? Could also upgrade to the BLX gear box. I have been running the same spur gear in my brushless upgraded mega and w/ the mega slipper with no issues. I am using the BLX gear box.
https://www.ebay.com/itm/143060168677
Yeah apparently I suck at setting the mesh! haha. I've gone through 3 spur gears!
But I can use this gear box on my Granite? What about the slipper assembly? Can I switch that up?
Is it a brushed Mega or a brushless 3S? Brushed 3S doesn't exist.
If it's a brushed Mega, it sounds like a mesh setting issue or stuff getting in the power module destroying the gear.
If it's a 3S, there is a metal spur gear available from Arrma.
That must mean you still have a 3mm motor shaft. Which brushless system did you buy? And would you recommend it?
Sorry yes its a MEGA brushed. Which metal gear works because I thought it was this one and it doesn't look right. The center is too large. How would this work?
This one will not work. It is the metal upgrade for the 3S slipper and the gear profile is different than on the Mega.
I am not aware of any metal upgrade for the mega.
Oh gotcha. Thank you for the help. Will the BLX gearbox work on my MEGA that Yonic mentioned?
Yes, the BLX slipper will work, but you will need to find a new 0.8mod pinion having the right hole diameter for the brushed motor shaft. I am not sure if this can be found.
Do you have a V3 Granite? If so, you could consider making the whole brushless conversion while you're at it. You'll probably do it anyway eventually. You will need the BLX slipper assembly + 0.8mod pinion + ESC + motor + batteries. The V3 already has the BLX- compatible diffs.
I have this system in mine and recommend it if you don't want to spend $50-60 more for the BLX spur assembly.
https://www.horizonhobby.com/produc...r-combo-3000kv-3.5mm-bullet-ec3/ONXS0500.html
Its pretty much a drop in fit. Can upgrade to a 17T pinion for a few more bucks that will speed it up too.
https://www.horizonhobby.com/product/pinion-gear-17t-48dp-mega-4x4/ARAC7784.html
Hope this helps. This system works best on 2s also. Had trouble with the ESC and Nimh packs.
Missed this one. Yes you can put the mega slipper straight into the BLX gear box either an upgrade to brushless or the stock mega motor.
One other thing is to out some loctite on the motor screws to help keep it in place over time. since I upgraded mine last fall I've only done a quick check on it a few times and it's still running the stock gear after countless packs through it.
Thanks. You hit the nail on the head - I hope to avoid buying a new assembly. You mentioned 2S. Have you also run it on 3S? If so, how’d it go?
Appreciate it. Last question: did you see any battery/efficiency improvement transitioning from brushed to onyx?
Yes, you will get longer run time with the brushless system. Runs at least 20 mins, longer of you turn down the power to 50 or 75%. My 4 year old drives it the most so its usually turned down but when I drive it at 100% it's just as fun as my BLX.
